Lebowski
http://www.nzz.ch/lebensart/auto-mobil/ein-fliegengewicht-von-einem-e-bike-1.17318558
...and folks, that's EXACTLY the sort of comment I would expect from Leonardo DaVinci. Thanks spinningmagnets.spinningmagnets said:I paraphrased the Google translation from the original German for electricbike.com: http://www.electricbike.com/the-lightest-electric-bike-ever/
The light weight of this bike makes it very easy to lift across cow guards in the road, and also over the fences and fallen boulders that are frequently found blocking the mountain paths, without any problem. "Thanks to the electric assist, my weekend rides have almost no limits, and I enjoy them very much”.
Chalo said:...resulting in neither a good bike nor a good e-bike...
2moto said:Chalo said:...resulting in neither a good bike nor a good e-bike...
How do figure that? Seems like the perfect e-bike to me.
John in CR said:My ebikes are one-crash bikes, but not because of too little weight or strength. Crashing is simply not an acceptable option.
Chalo said:John in CR said:My ebikes are one-crash bikes, but not because of too little weight or strength. Crashing is simply not an acceptable option.
And yet you ride a homebrew bicycle at automotive speeds on Third World roads, in a country well known for capricious traffic behavior. Hmmm.
Chalo said:2moto said:Chalo said:...resulting in neither a good bike nor a good e-bike...
Not enough structure to be adequately stiff for normal riding.
Way too little structure to be durable or fault tolerant.
No toughness at all; no way to absorb energy in an overload.
Not enough motor mass to sink significant heat, or to generate satisfying amounts of power.
Not enough battery mass to provide significant range, or probably power either.
No creature comforts-- inadequate saddle, hard grips.
It's the sort of thing that seems like a great idea in principle, but in practice there are very good reasons that even expensive, high quality bikes are not that light. In the business, we refer to such bikes as "stupid light", because they overreach for lightness at the expense of more usable virtues.
To put it in simpler terms, that's a one-crash bike that probably cost at least $20,000. Are you a gambling man? How large a bet would you like to make?
Chalo
It "looks like" the vertical part is the battery/ESC?I would like to see more of his bottom bracket design as well
kfong said:I'm sure it is much more durable than you think, Chalo. Carbon fiber is amazingly strong if professionally put together. This engineer has shown the ability to master this.
kfong said:Unfortunately carbon does break in a spectacular fashion. The layup has a lot to do with the quality of the product. I use carbon fiber masts for my windsurfing and have mistreated them and the still perform like new. Can't imagine using anything else. Even my cf ski poles have outlasted all my other poles and taken the abuse of luggage handling. If done correctly, I don't see why CF bike would not be a good choice to go with. I've been contemplating on making my own CF frame. If you have the ability to do your own layup, the cost is very reasonable. I would focus on strength rather than weight. Thick walled CF is rather bombproof.
It's a "thin-walled Scott Scale Carbon frame"...kfong said:I'm guessing this engineer did hid own layup work and I'm sure he is confident that it will hold up.
