Jerome Daoust
From E+ City Specs
E+ City was introduced at Interbike 2008 in September.
Spec Sheets are attached.
MSR Prices are as follows:
E+ City (24V, 550W): $2295
E+ City (36V, 550W): $2595
Highlights are as follows:
1. Up to 20 miles range (up to 25 miles range with 36 Volt battery
upgrade) with little pedaling.
2. Two Power Modes: Maximize range in "Distance Mode" (riding mode
1), maximize continuous power in "Tour Mode" (riding mode 2)
(delivers 550 watts continuous power).
3. Two Exercise Modes Work out lightly in excercise mode -1 or get
a hard work out in excercise mode -2. Each mode recharges battery up
to 250 watts.
Motor:
Power: 550 Watts (17.5 mph top speed)
Torque: 60 Nm (0 to 12.5 mph @ 8s)
Brushless & Gearless (No maintenance required, virtually silent)
Battery:
24 Volts (up to 20 miles range with little pedaling); upgradable to
36 Volt (up to 25 miles range with little pedaling)
Capacity: 10 Ampere-hour
Display/Controller Unit:
LED Backlit LCD Panel
Indicates: Speed, Battery State of Charge, Odometer, Cruise Mode,
Regenerative Mode and Five Riding Levels (two power modes, two
exercise modes and neutral)
Frame Set:
Size: 18" Platinum Silver or Denim Blue
Material: Hydroformed Heat treated Aluminum 6061
Front Suspension: Suntour XCT with Pre-load Adjustment and Lockout
Wheels:
Rims & Spokes: Dual Wall Construction, 26", 36 Hole, 14AWG Spokes
Tires & Tubes: Kenda Keen Tires, Thorn Resistant Shrader Valve Tubes
Drivetrain:
Shifter, Derailleur, Cassette: SRAM
Pedals: Wellgo Alloy Platform
Brakes: Tektro Linear Pull V Brakes
Other Components (Optional):
Rear Rack, Rack Bag with Panniers,
Front and Rear Fenders, Bottle Holder
Gross Vehicle Weight:
330 lbs (Rider & Cargo)
Cruise Control is Standard
Anti-Theft Mode is Standard
