Echo 56v bms issue
Plutus
Canada
Does anyone know how to reset echo 56v bms? Before replacing dead cell with identical one bms was showing 40ish volts between + and d-. After replacing all leds light up and i can observe 58.3v between + and d-.
Bms on this pack differs significantly from 58v pack it has 3x8 pin eeprom ics and 3x20pin ics. Eeproms are interconnected i assume its for addressing and also 3 controllers are interconnected too which i think 2 of them are for battery cell monitoring i.e each one has its designated group and the last one is master one.
There are no visible reset or rst pins only testpoint pins all over the board.
The problem is charger doesnt recognize it and also equipment doesnt do anything which i think is communication issue. Power mosfet is working as i can put a load between d- and + pins.
Tried holding battery indicator button for 30secs didnt do anything even tho i could observe some fluctuations at that time at pins s and d-.
Thermistor is good showing 10k ohms.
No loose connections or cracks board is thoroughly checked.
Shorting d and d- with 1kohm resistor didnt do anything either.
It seems to me that its in lockout state and needs a trigger to wakeup.
Anyone came across this problem?
