Ego batteries.
jay7264
longisland new york
Hi everyone I have 3 ego batteries that are no good for those original equipment. Charger refuses to charge. I want to put my own bms on all 3. Can I parallel the balance leads then parallel the main wires together. They are 14s. The cells inside are samsung 25r. Each pack is 7.5 ah I took them apart and did voltage checks on the balance leads. Would I just parallel all the balance leads from all 3 packs
Yes.
Just be very careful not to cross any wires.
The Ego batteries have some kind of serial communication with the charger and tools that is proprietary.
I'm using my own bms. The batteries show up as defective when put into a tool or charger. But the cells are just fine. Can you recommend a bluetooth bms that's good. 14s about 50 amp
