jimmyhackers
- Joined
- May 11, 2015
- Messages
- 609
i have two electric unicycle batteries....they are 2ah 16s lipo/li-ion. they came from two cheapy chinese 300w unicycles.
so max amp draw from them should be 300w/67.2v = 4.5ish amps. in their original designation
i noticed in a few cells were not balanced properly in one.....after manually/singularily charging them upto balance.....they have stayed reasonably well in voltage range with each other after a few cycles.
they come with an integral bms board. Does anyone know anything more about these kind of boards/cells?.
like max amp draw, do the bms boards have a max cut off amperage, how well (by what means) do they balance? etc etc.
I ask as i use them as a backup/emergency battery for my other ebikes, rated at 1000w and 1500w so like 13-21amps :s.
i wonder if i would be better of combining the two into one to reduce the currentdraw/stress on the cells?
any help would be appreciated.
thanks in advance
jim
thanks in advance
jim
