xrpb11a
Hi all,
I've been researching doing the above for the past month or so. Never electrified a bike before, but am pretty proficient with tools and such. I'd like some comments (funny and serious) on how you would configure this bike, versus what I have in mind at this point.
The bike:
HP Velotechnik StreetMachine GTE, SRAM DualDrive 24 speed ( 3 speed rear hub, 8 sprocket cassette ), front and rear suspension, 26" rear wheel, 20" front short wheel base recumbent, BSA 68mm bottom bracket.
http://www.hpvelotechnik.com/produkte/sm/gte/technik_e.html
The need:
All pleasure, I mostly ride bike paths and some street. Am at the base of sierra mountains so sometimes all flat, sometimes I have some hilly climbs...nothing very long but can get a little steep. Am looking to continue riding the bike like a bike, but have the option to maintain speed going up hills if I get lazy....sometimes engaging the motor on flats too just because I can! :lol:
No need to go real fast on this bike...20mph seems fine...I rented a pedalec which was limited to 15mph, and that was ok..not sure how safe a short wheel base recumbent would be at 25-30mph and don't want to be the guinea pig.
Started here:
Looked at hub motors. For my needs ruled out direct drives ( too heavy, big, adds to pedal resistance when disengaged ).
Looked at 250-500 watt geared rear hub motors...ruled out front hub due to Spinner Grind2 shocks, aluminum alloy dropouts, and short wheel base should something break and I go flying...
Rear wheel hub motor would mean I'd lose the rear hub sram dualdrive internal 3 speed, drop down to a 7 speed freewheel, and have to add two more chainrings to the current front single chainring ( I think 40 teeth ) along with the shifting stuff. Same dropout problems but probably minimized with torque arms ( although I don't like the idea of tightening the hose clamps on the torque arms and damaging the paintjob/metal )
Wound up here:
Started researching mid drives, since they would let me keep the current gear setup ( I think...SRAM internal 3 speed hub up to the task of a middrive?? ). Although they are not as stealthy, I could get good torque using the gears to minimize motor burnout and use intelligent gear shifting to eliminate chain wreck...
Currently looking at 350-500 watt BBS01 / BBS02...
This place:
Has got so much info, and I have absorbed and read so much in the past month that now I am on information overload and frozen in my tracks in the decision making process
Any and all comments welcome. I need some objective 3rd party viewpoints to regain focus!!
How would you go about electrifying this bike??
The bike:
The need:
Started here:
Wound up here:
This place:
