Im building my first e-board using a loaded vanguard w/180 mm paris trucks. Using the torqueboards motor mounts, will I have enough room to mount two turnigy 6364 sk3 motors? Im worried there will not be enough horizonal clearance for both.
6354 would fit but only on 195mm trucks. A two piece motor mount is ideal for a tight fit which might be able to make it work.
I wanted to upgrade motors to 6354 too and use dual rear but it's tough to fit the space.
50mm's work great though. Doubt the 6364 would make a huge difference unless your adding more power to the setup. Besides the added durability of being a bigger motor don't think there's much benefit.
