fardriver nd72260 - reverse not working
Loppi
Hi.
I got a Fardriver ND72260 controller. When I do auto-learning with wheel of my scooter lifted in air; wheel spins to both directions as it should. After auto-learning, if I press reverse button while turning throttle, rotation direction of wheel changes and it works perfectly. Or almost perfectly, I haven't found a setting to limit reversing speed - it would be very difficult to reverse in high speed..
But when I go to a test drive, reversing no longer works; if I push my scooter to go backwards and reverse at same time, I do notice that it tries to go backwards, and if on a flat asphalt, giving a push to scooter (while sitting on it) to backwards, and doing same with reverse button + throttle, the second one will go further backwards; it would seem that there is not enough power available for reversing, because if I lift it off from the ground again, wheel spins backwards perfectly.
Good ideas?
First,make sure the reverse line right connected to the R switch
Then enable the reverse function per APP by BT.
