From the ashes of defeat...
To salvage some of the time/work/materials put into this build http://endless-sphere.com/forums/viewtopic.php?f=6&t=14788, I'm modifying the triangle enclosure to fit my trusty old Fetish Obsession frame. This is the bike I've been riding for 1200+ electrified miles with a standard rear hub kit from ampedbikes. As it was sitting, I had the controller and wiring mounted to the seatpost and I used 4 Boshc fatpacks in a backpack set-up. The batts plugged into the pigtail coming off teh seatpost.
There's a five speed freewheel on teh hub, but I found I only used top gear. The cheap 99 cent falcon shifter I got from Nashbar works if you need to limp home in a lower gear, but I wouldn't recommend it for regular shifting duties- no index, friction shift.
The acrylic box just hides excess wires.
The whole rig weighs in at 42.9 pounds.
