Hi all,
Thanks you all for the great info here.
I built my first LiPo battery from new drone batteries (Xiro Xplorer 11.1V 5200mAh) making a 10S4P battery pack.
(the drone batteries were 3S2P and a bargain at $15 each)
According to my calculations this is a 37V x 10.4Ah = 384Wh battery.
When I charged from 35V (resting) monitored the charge with a Mooshimeter (logged the voltage and current every 1 minute).
At charge termination (2A charger) ... when I calculate the charge in I recorded 431Wh.
Should I be concerned?
Battery is not warm during charging, has a BMS attached. Are the batteries that over spec'd?
I calculated the charge in by summing per minute Volts*Amps/60. Is this wrong? I figured it would be closed enough as the rate of change of voltage and current is minimal per 1 minute period.
Thanks!
Thanks!
