Ptown_Cruiser
- Joined
- Feb 18, 2015
- Messages
- 19
Hey everybody,
I have been really loving all the great info on this forum, and it has been helping me a ton as I have been getting ready to jump into my first build! I have a few questions but before I get to those here is what I am looking at for my build:
Motor: single SK3 6374 192 KV
Gearing: 2:1 (18t, 36t 15mm width 5mm htd belt)
Esc: Hobbywing 150A
Batteries: 2x3s 5000 or 8000 mah in series
Trucks: Caliber 44
Wheels: 83mm flywheel clones
Mounting bracket: custom (I will design and machine this my self)
Questions:
1) My biggest question right now is about the motor: I am a pretty heavy guy (~230 lbs) and I want to make sure that I have enough torque for decent hills, it doesn't need to be anything crazy, but I want to be sure I can handle most hills. Top speed I am looking for is about 18 - 20 mph (which it looks like I would get with the above setup). I know that the best thing would be a dual motor setup, but I am pretty set on going with a single motor setup on my first build (both because of lack of experience and cost). Would the motor/gearing combo above be enough? would it be overkill? I have also been considering the SK3 6364 213 or 190 kv motors, would one of these be more appropriate?
2) I have tried to read up as much as possible on the noisy breaking that you get with a lot of ESCs but It doesn't really seem like there is a definitive answer for this. Is there anything that can be done about this? are there any ESCs that don't do this?
3) If I use 6m bolts through the flywheel clones, do I need any kind of adapter, or do they fit in the stock wheel?
Thanks in advance for your advice and help!
Esc: Hobbywing 150A
Trucks: Caliber 44
Questions:
