First M/C build. What do I need
spdas
Kapolei Hawaii, USA
Aloha All, I have built my "bicycle" setup and now want a bigger road worthy motorcycle, so to cut to the chase ------------------
Here are my parameters
For a motorcycle/Scooter (125-150cc frame) which motor and controller would I use to do the following:
1) 50-55 mph (85kph)
2) 72v-96v
3) Battery volts/amps needed to make it for 50 miles or 80 km?
I am thinking about using the leaf,com hub motor described here.
http://www.leafmotor.com/hub-motor.html
Motor:gearless bldc hub
Voltage:48V~72V
Power:1500~5000W
Net Weight:13.5kg/30lbs
Tire: 4.00×12inch
20" inch hub motor wheel for electric motorcycle.
20inch electric motorcycle motor
and lipo Batteries
5000mah (8 in parallel = 40ah) and going to 24s for a total of 48 cells..... hard case like here:
http://www.ebay.com/itm/2-TURNIGY-5000mah-4s-14-8-20c-LIPO-BATTERIES-1-8-LOSI-RC8-OFNA-TRAXXAS-/322268327175?hash=item4b08b06d07:g:tPoAAOSwe7BWvhGJ
Comments?
Francis
Aloha, I just bought this hub and working a bit on the frame for the wheelchair trike. (similar style to the gas 'ped below.)
QS V3 Hub Motor 4000w-6000w 1500rpm Electric bike, Scooter, Motorcycle 4kw-6kw
This is what my gas moped trike looks like that I will now make another the same style and EV
