Freewheel crank from Boosty switzerland
jk1
Have you all seen this freewheel hub from boosty ?
http://www.boosty.ch/en/conversation-kits/crank.html?page=shop.product_details&flypage=flypage.tpl&product_id=212&category_id=5
looks pretty good- and also pretty sturdy
I am wondering if anyone has used on and how reliable was it ?
Does this use the CSK 35 sprag clutch or something better ? seems like it is screwed together and hence you can change the freehweek if it fails which is a good idea !
would this be stronger then the Cyclone/Elation version ? it doenst look cheap though :p
It uses an Echo freewheel.
ahhh so dikta is even worse then a csk 35 freewheel ?
Does anyone make a strong relaible freehweel as the csk 35 is not that good- they slip after a while
