cycleops612
Clearly, solar is too; weak, bulky & heavy for general off grid ebiking at this time.
you can get an idea of whats commercially doable here, but am v skeptical of claimed power & odds of good sun when riding.
http://www.ridethesolarwind.be/en/product.php
If, as one does, you make camp at sundown, well oriented panels dont help.
Wind power, however, is concentrated solar when it blows.
Should work. Discuss, & somebody start making them
Great for 3rd world.
Very roughly, E.G.:
A rear hub drive bike w/ regen.
Hang bike from a high ~lateral tree branch (or a high line between 2 trees) by rope/strap to e.g. the front rim, so bike is suspended in clear space & can ~swivel (as wind gens do).
Maybe guy/ballast it a bit for orientation/stability. If wind changes radically (an alarm?), may have to manually adjust orientation a bit.
Contrive:
A vane for orienting the suspended bike to the wind
Apt size sails/spinnakers for the pedals using light nylon cloth & cord, & obviously, sufficient anti snagging measures on the bike, again light nylon cloth - a bike stocking?
Maybe the sails need keeping away from the bike a bit? (or vs versa, swivel handle bars a bit?) Some light, bolt on, pedal extension/rigging? Possibly just shaping sails right.
In a suitable derailleur gear, the fill/flap/fill/flap action on the cloth sails/spinnakers/kites), turns the chain & the motor regens that force to the battery as charge.
I suspect a problem w/ the pedals being opposite one another on the crank. - lateral rocking.
As far as I can tell, moving one pedal 180 degrees on the crank quickly doent look hard.
So, perhaps this rocking could be moderated, if one pedal arm were moved 180 deg. on the crank, so both sails pull together, rather than alternately.
I dont see a forward/backward rocking in line with the wind as a problem.
An issue is, regen often? has no BMS ability?
A normal .2c domestic charger for a 500wh battery is charging at 100w. This rig may well approach or better this. Its limited only by wind and sail area.
Recharging 1kwh or more reliably overnight in some areas seems very possible.
Curiously, the usual limit to effective pedaling does not apply. Wind resistance.
It sounds noisy tho. If it flaps, it sounds some springing like ~elastic sail ropes may help.
Improvisation that uses dual purpose bits from existing touring kit is good. Flagpole e.g.?
In short, in a breeze, u can; recharge as u camp, using a; substantial, free, 100% clean; ~no weight ,source.
It seems a natural fit to use the mechanism you already have, as a wind generator. Make your pedals a wind turbine?
great control over gearing to the breeze strength, and even cool instrumentation - speedo/motor rpm/charge level etc?
If you are doing touring right, "meh, the wind may blow tomorrow". I will explore here today.
If it doesnt weigh anything, its a no brainer to have along as an option, along with mooching use of a wall socket to charge.
less need to drain batteries for onite campsite use, and times of plenty of campsite power spare.
Maybe a fast charge during lunch if breezy? with the right tree branch, it could take under 10 minutes to set up.
A good fit is remote mountain touring. Need plenty of power, have regen anyway and have plenty of wind.
Very roughly, E.G.:
Contrive:
