Thanks, bro. Super thankful. That thread is awful useful with 141 pages, and 3506 posts of highly relevant info!
It's about the kit that has 1.5 kw less than mine, and nearly 1/2 the voltage though. I think I'll just guess at random which motor parameters to cut in 1/2 / 2/5. I'm sure I won't break anything, since there is so much safety margin built into these parts to begin with.
Do you think plastic calipers are good enough for an interference fit? I was hoping for an interference fit on this crapulent jackshaft, and sad little freewheel.
I need to make a custom mount for this thing. Is JB Weld good for that? I really like delrin, but filing delrin by hand is such a pita. If only some good Samaritan would have had a 3500 post thread about how difficult delrin is to file by hand, I would have read the whole thing, and saved myself -42 hours of grief.
I have no idea what these threaded, hard coat anodized pedals are made of. I've heard that brine quenching, and age hardening is the best way to make strong parts, They're supposed to be reeeeaaalllly strong. I don't want stripped threads like all those other posers. I've heard it is applicable to all alloys, and makes the part both super-tough, and ultra hard. It's also not supposed to cause the part to warp at all, heating it above it's solution temperature.
Thanks, bro, thanks so much. I'll be sure to search around some more before posting anymore idiotic questions.
Anybody know anything about the 72v kit? Even just the rpms, and amps would be helpful. I used the search function, really I did. It took me a couple hours to find the button though. :x ! I just couldn't find a thread with any useful info.
Thanks for all the help so far though!
Edit:
I found this info, but it only goes up to a 750 watt motor:
http://www.gngebike.com/motorspecification.htm
I guess if I take the 500 watt motor rpms, and multiply it by 5, that should give me the 2500 watt motor specs. So it looks like a 15,000 rpm motor. Man I'm really glad you turned me on to search engines. This google thing is the bomb!
