alsmith
What kind of connector do you use for the hall connector wiring from the wheel to your wiring harness?
My crystalyte uses a small 5 pin latching connector which I've had a few problems with soldered wires breaking (not helped by the poor quality of the original wires, I'll replace all 5 at the next motor stripdown). Soldering them is getting hard- I think age is now affecting my ability but these pins only have maybe 2mm between them on a 9mm round connector.
The connectors should be a latching type, preferably separate pins that are assembled info the connector for easier soldering but not essential, and waterproof would be nice. I was thinking about the ampseal type, but they are quite large (inline format pins).
What else is there, and what is recommended?
