yep, sent you a pm, it is the output cap, i doubt if something like radio shack even has them, but if there is a good electronics store there, then they may have one. but it is cheaper and usually faster to buy one off the electronics sellers on ebay. you can buy one a little bigger too, or higher voltage, but you have to make sure the legs will fit since they have different spacings for different size caps, you can look them up in mouser, radial lead electrolytic capacitor. 50-63V and 100-200uF should work.
edit, if you can get it away from that heat sink that holds the output schottky diode, it will last longer too. but that is where the larger cap would be too big for the space.
