i just bought 24 Volt 500 Watt motor controller with reverse function,
but i dont know about wiring diagram for this controller,
any body know about wiring diagram for my controller?
The others??
Not seen a controller with so many single wires before,
Of the the doubles, probably:
Reverse
Brake
Speed?..though speed is usually three wire..but could be speed wired in cyclic / momentary switch mode
Neil's got you running with the main wires. Then with wheel off the ground and maybe a helper you can check the others. My guess on the 2 wire plugs are reverse and/or ebrake , and momentary switches for cruise control and/or 3 speed switch. The single purple and green are ? Turn it on and check them for voltage, but one could be a speed sensor wire. My guess on the yellow would be a 12V ebrake fed from brake lights.
Do you understand how the on/off wire accompanying the battery mains wires works?
Do you know how to find the correct wiring combination for the motor wires?
