Cars and motorcycles are banned where I live, so bikes are a key form of transport. In summer the temperature is 33-35degC (90-95degF) with humidity in the range 70-99%, rust is a real problem. The majority of electric bikes look like this:
My current bike, based on a Fuji Odessa, uses a Cyclone Taiwan, single chainring, 500W motor kit and a 24V 20Ah LiFePO4 battery – a straightforward installation. Gearing is:
14-tooth sprocket on the gearbox output shaft (internal reduction ratio 9.55:1) to,
44-tooth chainring (30:1 reduction ratio at the crank) to,
13 to 34-tooth cassette on an 8-speed rear-derailleur (26in / 660mm wheel).
[maximum crank speed is 80rpm to 90rpm so I can match the cadence - just].
The bike has now travelled more than 1,500km (950ml); recently I re-tightened the drive mounting bolts and removed 2 links from the chain. The bike weighs 25kg (55lb) and I weigh 100kg (220lb), in riding gear. The folding trolley is used for groceries, suitcases, scuba gear etc. Sometimes my wife travels, sitting sidesaddle, on the rear carrier – she is much lighter than I am.
The Cyclone battery is in the black bag suspended from the top tube by velcro straps.
I ride daily and use a cheap bicycle computer to measure both speed and distance (checked by GPS). No pedal-assist top speed is about 35km/h (22mph); I normally ride at a more leisurely 25km/h (15mph). However, the bike struggles with steep mountain paths, where tight twists and turns prevent any sort of run up. The incline limit, with me onboard and pedaling, seems to be about 13%, but the paths I wish to take are much steeper. The photograph below was taken on one of my favourite routes, at the point where the bike could go no further:
So decision time,
either
modify this bike by fitting a 3 piece chainwheel or 3 speed SRAM dual drive or
build another one?
I decided to build another bike with the aim of better hill climbing ability. After reading many threads (contributors, thank you) and seeking recumpence’s advice (Matt, thank you) I ordered an Astro 3210 brushless motor (10 turn), a Matt 2-stage drive, a Castle Creations HV110 and a 12S 10Ah Zippy Flightmax LiPo pack.
OK, I really wanted to try an RC motor!
The complete drive system weighs approximately 7kg (15lb), so I have set myself a target of loosing 7kg – no more cheesecake for a while!
I will start a separate thread “Hill climbing - Astro 3210†for the new build.
So decision time,
either
build another one?
