Hi ESFMs,
One of my motors has a damaged bearing and I'm only just now getting around to shopping for a replacement.
I'm not sure I'm measuring my current bearings correctly. I've measured an inner diameter of 15 mm and an outer of 35 mm. However, when I look for bearings of that dimension, I can't find anything that matches. The closest I've come across is 16 mm inner with like 26 mm (+/- mm).
Is there a special way to measure bearings? I've just been measuring the very inner diameter and the very outer diameter.
Clinton
Clinton
