Cowardlyduck said:So in my situation I previously removed the side covers without marking them.
Reassembled, they are out of balance, however I also drilled them, so I don't know if this would effect things also.
Any tips for re-balancing drilled side covers...without specialist tools?
Cheers
Or, just not worry so much about scraping the magnets, and push the Rim down onto the floor with both side covers undone. That way the stator just pops out the top.NeilP said:if you do no have a vice to clamp the axle to, to pull.
Drill a hole in a large piece of wood...countersink the hole one side, put washers and wheel nut back, then put on floor. Get others to stand on wood to hold it down..or screw it to floor then pull the rim off upwards
