Here is what happened:
1st attempt:
Got DP420 Epoxy black on ebay. Applied it by sanding the aluminum dropout to expose the metal and epoxy Doc's Torque arm to the expose area of the aluminum. I allowed about 1 day cure. About 1.5 months later, it started to peel off my ebike.
I figured it was a fake, and went out to buy it from a reliable source,
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=DP420+black&op=search&Ntt=DP420+black&N=0&GlobalSearch=true&sst=subset
2nd attempt:
This time, removed all the old DP420 stuff on the bike's dropout and applied it again. Did the same thing again, but this time, allowed 1.5 day cure. Now about 3 months later, one side started to crack. See picture below.
Am I applying this wrong? Do I need to wait a full week before I use my bike? Do I need more DP420 black? I know from building other stuff, to use minimal epoxy as if you put too much, it might make it weaker.
Keep in mind, I am using this torque arm on a full suspension bike with regen enable set to minimal regen strength.
1st attempt:
2nd attempt:
