Anyone ever seen something like this before? I hadn't, and stumbled upon it in my local ebike shop. They were custom machined. Seems like a brilliant idea - you can lengthen your axles easily like this. Two scenarios that I can immediately think of that are good for this are 1) using a front motor in a rear application, or 2) using a hubmotor in a fatbike (no more rears in the front!)
I bored one of the out to allow for the axle wire to exit. On a motor with a side exit axle that wouldn't have been necessary. In the course of boring it out, I discovered that either my bits are sharper than I remembered or this is seriously soft steel. I'll remember that when it comes time to crank down the axle nuts.
Also I'll need to add on some flats for wrenching and a torque arm. Still a neat idea though, if not quite a finished idea.
