Lurkin
I am planning my next bike now. The prior was a hardtail, 250w Bafang mid drive.
Requirements are:-
- higher reliability
- more power. thinking probably 1000- 1500w should be sufficient.
- low complexity motor
- inconspicuous to avoid unwanted attention (rules out mid drives like GNG etc)
So that leaves hub motors, drive drive or geared. I was originally planning a high power bike with a flux frame and 3000w mxus motor. Whilst this would have the ease of use with a decent battery compartment, it's just for commuting on bike trails with a max speed of ~45km/h and a crusing speed of around 35km/h - seems like is overkill/ over expenditure. Accordingly, I considering switching back to a bike retrofit.
I've had a bit of search on the net re hub motors but not too sure where to start. Really, I need a hub motor which is smaller and can pass off as a large hub or dynamo hub rather than a larger motor. i.e. the brake disc and cassette should help conceal it.
At this stage I think I would prefer direct drive because I really, really appreciate the simplicity of the design. However, others have noted geared hubs would extend range (will need to do 80km per day on this).... I really don't want to have to deal with fiddly plastic gears again.
What can you suggest for me?
Requirements are:-
