Hub Motors -vs- Mounted Motors
onloop
LETS DISCUSS THE PROS & CONS OF:
Hub/Wheel Motors For Electric Skateboards
VS
Motor Mounted with pulley & belt
List your pros/cons of each & discuss.
In this application hub motors are very promising. You don't get selectable gears so if you can get the kv right you save some weight, parts to break, and drag. The downside is you Can't make gear changes, and its probably difficult to fine tune the kv of a motor.
