This is something just in an idea stage. Ever since I was a little kid, I've always been facinated by jet engines, but never got to play with one. This may be a way to make it simple.
Basically, take an electric ducted fan and attach something like an afterburner to it. The idea is to heat up the air enough so it expands to several times it's original volume, increasing the velocity coming out of the tail, increasing thrust. With a typical military jet, the afterburner nearly doubles the thrust. If starting with cold air instead of hot jet exhaust, the afterburner might give more than 2x increase. Modern ducted fans are pretty impressive by themselves.
A glow or spark plug would be used to ignite the fuel. Fuel flow would need to be controlled such that the optimum rate was given depending on ducted fan speed. The burner could be turned off and restarted mid flight. Maybe a good idea to place a pyrometer somewhere to throttle back fuel if it gets too hot.
A coaxial tube design with a fair amount of bypass air between the tubes would keep the outside temps down (hopefully) as it would tend to get red hot or melt. All the parts that get hot would be fairly simple sheet metal pieces. No high temperature turbine blades or bearings to worry about. Where can I get titanium beer cans?
This design could use nearly any type of fuel. You'd try to carry just enough fuel to last as long as the batteries.
I think this could be scaled over a wide size range. World's smallest jet? Personal jet pack?
Even if the burner part didn't add enough thrust to make up for its weight with fuel, it would look and sound really impressive, especially at night.
So, is there some obvious reason I've overlooked why this couldn't work?
