alex12342011
So I have a 14s 10ah pack, composed of lithium manganese cells. I charged the pack succesfully with no issues the previous day, and all of the cells were balanced. The battery read 58.8 volts hot off the charger. Now today, I wanted to cycle the pack. I plugged in my main and balance leads, dialed in the correct settings (Capacity at 10ah, # cells at 14, lipo) set the charger to discharge, and away it went. First I noticed the fans humming louder and louder, then there was a pop followed by the smell of burnt PCB. Immediately I disconnected everything, and sat puzzled as to why this happened . I then remember that the software set the discharge rate to 10.0A, it took the capacity of the battery pack and discharged at 1C. When the fans were getting louder, the amps onscreen were reading about 1.4amps. 58.8*1.4 is about 80 watts, which turns out to be the maximum discharge capability of this charger.
Did it really blow up because it was trying to throttle the amps slowly to 10.0A?
Do you think this was user error (me not verifying the discharge setting), or was it the charger's fault (charger setting 10.0A by default, way over the 80watt maximum for a 14s pack)?
I am trying to get this covered under warranty, as I bought it less than a month ago.
