Cyclotron
The constraints:
- It's Germany, so the motor needs to have a 250watt sticker on it that isn't obviously lying
- Pedal assist only; whether cadence or torque based
- It needs to be demonstrably unable to exceed 25kph under motor assistance. (is EggRider still the state of the art in this area? I'm not handy enough to hide a reed switch)
The optimization target:
- My 12km commute includes a 3km hill with 400m of rise.
- I'm 6'2", 250lbs, and in my 40's; and I don't want to arrive at work sweaty
- I want to go at least the max legal motor-assisted speed--25kph--the whole way
- I'm not experienced building bikes--even acoustic bikes--so the more pre-built the solution is, the better.
After reading the articles on ebikes.ca, I think I need more amperage and less voltage; and that the "250 watt" sticker has a very fuzzy meaning. So I could probably do this with a 25Amp-35Amp motor controller, some overbuilt "250 watt" hub motor which is compatible with statorade and heat sinks. But I don't know how to calculate just how much torque I need at which rpm to do 25kph on a 20% grade.
