Icharger 4010Duo Lipo Charger!
mvly
Here are the specs:
Specifications
Input voltage range: 9-50V DC
Input current limit: 65A
Maximum charge power capacity: 1400W per channel @ >23.5V (up to 2000W in synchronous mode)
Charge current range: 0.05-40.0A per channel, or up to 70A in synchronous mode
Discharge power capacity: 130W per channel, or up to 200W in synchronous mode
Maximum regenerative discharge: 1400W per channel, or up to 2000W in synchronous mode
Maximum external discharge power capacity: 1600W @ 40V/40A, or up to 3200W in synchronous mode
Current drain for balancing: 1.2A per channel, or up to 2.4A in synchronous mode
Balance accuracy: 10mV
LiPo/LiIo/LiFe: 1-10 series per channel
NiCd/NiMH battery cell count: 1-25 series per channel
Pb battery cell count: 1-18 series (2-36V) per channel
PC Connectivity: USB port
Weight: 1470g
Dimensions (LxWxD): 210x140x80 mm
Warranty: 1 year
Further specs and manual coming soon!
Here is the link:
http://www.progressiverc.com/icharger-4010duo.html
I wonder if I can charge my 20s Lipo with this without breaking up the battery into 2 37V Lipo pack.
