Hi,
I am building a ebike with a BLDC motor rated at 3kw (nominal). I was thinking of a kelly 3kw KEB72301X controller, but Fany at Kelly controller tells me this will not be adequate and should go for the 4.5kw KEB72451X controller instead. But it costs nearly 20% more ($259 vs $219). She says for optimal performance the controller should be 1.5 to 2 times the power rating of the motor. I don't get this. Can someone explain why this is so? I am a bit of a noob
. Is she right in suggesting the 4.5kw controller or is she just trying to up-sell. :?
The specs of the 3KW controller are
72V 3kW
•Peak Phase Current, 10 seconds: 150A.
•Continuous Phase Current Limit: 60A.
The motor is a Golden motor 3kW @ 72V
Thank you
72V 3kW
Thank you
