Is this sprocket too big for this wheel?
patrickza
It's for my outback mountain board. The wheels are 12.5" or 318mm diameter and the sprocket is 246.1mm in diameter. The rim is about 210mm in diameter I think, forgot to measure. Oh yes, the chain is a 05B chain but I'm not sure that maks much difference. The smallest I can get for my turnigy 130 is an 11 tooth, so if I can fit this 95 tooth on I'm smiling. The next size down would be the 76 tooth at 198mm diameter, it'll easily fit, but give me a 1:7 rather than the 1:8.6 I'd prefer.
Here is a cardboard cutout:
and the clearance:
So any thoughts or does this look like I'll make contact with the sprocket if I hit a bump?
personally i wouldn't do it. The chain will also add a bit of diameter to this. if you got a flat, or simply didn't run enough air in your tyre you could be in a spot of bother.
And yes i'd be worried about bumps, breaking teeth on the sprocket, not to mention clearance of the tyre.
It doesn't need to lean right? How rough is the ground you cover? I think the terrain is going to determine if this 1.4" clearance will be enough. "Mountain" part of the name makes me think you go over rocks and stuff?
