SlowCo
[youtube]AQV-Ia5Cx9E[/youtube]
Awesome!
Awesome!
Get real !…There is nothing silent about any prop driven aircraft !…silent commute. ??..
Hillhater said:Get real !…There is nothing silent about any prop driven aircraft !…silent commute. ??..![]()
Even Owls and Bats make a racket when they take off !
Actually i was thinking more obout all the electric drones that are becoming common..The modern prop driven aircraft that most of us know is powered by a internal combustion engine with no muffler system on the exhaust.
Hillhater said:Actually i was thinking more obout all the electric drones that are becoming common..The modern prop driven aircraft that most of us know is powered by a internal combustion engine with no muffler system on the exhaust.
…nothing silent about those.
And those turbine powered helecopters that you hear the blade beat way before they are close enough to see or hear the low wine of the turbine.
I can understand that this is “less noisy” …
…..but silent it will not be !
PaPaSteve said:Blade profile on these modern electric props are designed to pull at the same amount regardless of diameter where each profile resides. i.e. inside diameter pulls the same load as the tip.
Chalo said:That's been the design intent of aircraft props since the Wright Brothers got distracted from making bicycles. If you hadn't noticed, they're still very noisy. So much so that jet engines are a quieter alternative.
Chalo,Chalo said:That's been the design intent of aircraft props since the Wright Brothers got distracted from making bicycles. If you hadn't noticed, they're still very noisy. So much so that jet engines are a quieter alternative.PaPaSteve said:Blade profile on these modern electric props are designed to pull at the same amount regardless of diameter where each profile resides. i.e. inside diameter pulls the same load as the tip.
red said:Chalo,Chalo said:That's been the design intent of aircraft props since the Wright Brothers got distracted from making bicycles. If you hadn't noticed, they're still very noisy. So much so that jet engines are a quieter alternative.PaPaSteve said:Blade profile on these modern electric props are designed to pull at the same amount regardless of diameter where each profile resides. i.e. inside diameter pulls the same load as the tip.
IIRC, the Wright Brothers tried then abandoned the research for an ideal prop, saying the problem may not be resolvable. Now we have the ability to get the design right, with computers.
The Un-Ducted Fan (a modified turboprop with counter-rotating blades) is reported to be significantly quieter than the normal airliner.
Yes, of course.PaPaSteve said:Have you viewed the video in the opening post ?
…[ assume you ment “whilst” rather than “which” ?]..”Blade speed is reduced as much as possible which maintaining enough lift”..
liveforphysics said:Wright brothers props were efficient only because they were spinning 350rpm with 6hp going into a large disc area.
Huge respect to you PaPaSteve, I don't know if we ever met in person at Joby, but the propeller is 95% of the design magic in a VTOL being practical to use in urban environments. I remember the hours spent on the prop dyno scratching my head at the grams of thrust/watt numbers, and how some efficient props were surprisingly loud, despite wasting that extra energy in noise. Achieving both low noise and great thrust efficiency and peak thrust numbers is one of the most formidable design challenges humans have tangled with.
