MitchJi
Hi,
Very Clever Idea. Seems like a perfect compliment to Solar Thermal.
Main disadvantage appears to be that it requires a no fly zone but:
http://www.kitegen.com/en/technology/details/
From their FAQ:
http://www.kitegen.com/en/technology/faq/
Two Styles (Stem/Stem Offshore and Carousel [they are working on Carousel Offshore ]):
http://www.kitegen.com/en/products/stem/
http://www.kitegen.com/en/products/kite-gen-stem-off-shore/
http://www.kitegen.com/en/products/kite-gen-carousel/
To help visualizing the existing unexploited potential, just consider that the flight prohibited area over a nuclear power plant can easily get to contain 1 GW of wind power, equal to the power of the plant itself.
From their FAQ:
[youtube]Zl_tqnsN_Tc[/youtube]What is the cost of the energy produced by a Kite Gen power plant?
A 100 MW Carousel power plant is estimated to deliver energy for less than 0.03 Euro per kWh, which is cheaper than fossil fuel-based generation. Even lower costs are to be expected from bigger and more powerful plants. In the Stem configuration the foreseen cost is around 0.05 € per kWh
How does wind power change with altitude?
As altitude increases, average wind speed increases (and remember that wind power grows with the cube of wind speed) and air density decreases. Wind power decreases linearly with air density, but even at 1000 m air density is reduced by only about 10%. Wind power therefore always tends to grow from ground up to approx. 10,000 m of altitude.
The following video shows how the Stem generator works:
Kite Gen Stem
In the “Stem†configuration the wings pull the cables that, through a pulley system, activate the alternators on ground, that produce electricity. When cables are entirely unwound, the wing is guided to a position where it loses its wind resistance and the cables are wound in. Energy consumption of the winding phase is a minor fraction of the energy generated during the unwinding phase...
In 2006 Kite Gen Research has built a first prototype, codename KSU1, tested at an altitude of 800m with the authorization of ENAC and ENAV (Italian Civil Aviation Authorities)...
eyond the verification of the theoretical data, the KSU has produced energy, thanks to the unwind/rewind cycle: 5kW average and 30kW peak, with a ground of 4.5 m/s.
Stem configuration has been producing today and functioning of the first generator, near Asti – a place where wind conditions are considered to be definitely inadequate to traditional wind generators – is foreseen for the end of 2009.
Kite Gen Stem Off-shore
Kite Gen Carousel
The configuration combines a series of Kite Gen generators, considered as a “base†module, where the tension in the cables is maintained constant and their length changes only to grant the wings control, in order to obtain the optimal trajectories for energy generation.
As the power kites circle in the air, at an altitude of 800 – 1000m, the vertical rotating axis of the structure activates large scale alternators, that have been geared down to receive the force exerted on them. At its full capacity the flight of the entire power kites array is guided, so as to turn the carousel at the desired speed, with a capacity factor estimated at 5,000 hours per year.
Maximum reachable size is under study, but first evaluations shows that 1,000 MW (1GW) can be exceeded, without significant structural risks, with a diameter of approximately 1,600m.
