alex12342011
Hey guys,
Decided to share my work in progress.
2005 Kona Kikapu, 20" frame.
9C 2806 Rear Kit
Schwalbe Big Apple 26x2.35 Tires
Avid BB7 front brake and Nukeproof pads
Grin Universal Torque Arm (this has worn out and the axle tries to rotate during regen after a year of use)
Stator varnished and internals sprayed with oil. This is a must if you plan on venting your hub and running wet.
Controller is a 9FET Lyen, programmed to 40A battery/90A phase.
Battery is made up of Emoli IMR26700 cells from Milwaukee powertool packs. 14S6P giving me 58.8V and about 11AH fully charged.
Falcon EV frame bag.
Yes this will stand up to rainy weather, but the zippers have waterproof strips covering them which can easily tear after abuse.
Zippers themselves are fine, just the thin waterproof flaps aren't something that will last if you keep zipping/unzipping.
Top speed on the flats is 55kph, with 230lb 6'2" me on it.
Here is the first iteration of my build. A bit half-assed as the frame bag rubs against the rear shock. And all electronics sort of stuffed into the frame bag.
My first order of business is to upgrade how the battery mounts to the frame.
I will be using 1/8" polycarbonate to make a box. Here I have made a mockup with cardboard for test fitment.
More to come...
9C 2806 Rear Kit
More to come...
