Lets see what we know and dont know and do some review .
First some questions;
How old are the batteries, have they ever been replaced? If replaced did she get the right repacements (B and B B BRand EV specific model. Gruber or Panasonic?)
Batteries are at least 3 years old, that is why we are looking in to other options or just going back with stock
What exactly in dollars are the budget goals?
Say $300
Is the ebike well maintained bicycle wise; tire inflation, brakes, wheels trued, chain lubed?
Yes
How fast does the lady go on the bike? How heavy the load? Does she contribute a lot pedaling, or only minimal?
She has had it maxed out for speed she claims and carries moderate to light loads and does pedal because she has to with the PAS
does she charge the pack while going on errands? AT home did she leave the pack on the charger several hours after going green?
No and Yes
How tough are the hills; slope and length?
5 or 6% up to 1/2 mile in length
I owned a Lafree Sport as my first ebike; I worked on many. I never asked it to go over 9 miles without some charge. If you have a Lafree, you need to know how to take care of SLA batteries; charging them often; minimizing the time uncharged, minimizing heavy current draws -- all these things maximize range and battery life. If these batteries have many months on them and havent been cared for very well, they have reduced range and possibly maximum current delivery capacity. Staying in the lowest useable gear increases motor efficiency.,
Duly noted
The Lafree is a heavy bike. It has a nice 400w brushed chain drive motor with almost 1000w peak power. But that power and energy must come from its 24v SLA batteries. That is 40 amps peak when the rider forgets to downshift before stopping, then starts up in much too high a gear- for the motor and the legs. Heavy current draw like this decreases the true SLA AH's available versus any other chemistry at identical AH's, by a big factor, maybe 35% especially by a user not managing maximum current draws.
Duly noted
It is very nice to have a chain drive ebike IF one uses the gears correctly; but on a standard rear deraileur bike it is difficult for the operator to downshift several gears from a very low speed up a hill. This is mainly a Pedal assist bike with a short term throttle(~5 seconds) for tough spots, with a off/ full power/ economy switch on the handle bars.
Agreed
As it sits, I am not sure this is a great match of an ebike for a 70 year old lady. It has to be ridden and shifted correctly, it is heavy, it has a short range, the SLA pack and charger need to be understood and used accordingly. It is a step thru frame, known as womens frame in previous days.
But at this point it is the one she has. I could buy it from her I suppose but for what it is worth and her top budget amount it would not do much to get her anything better that I can see so for now I think she will stick with it.
The chain drive is fine, but I would prefer a nexus rear internal hub that can be shifted more easily. I would have prefered a Nicad pack stock, a very rugged chemistry with pretty good current capabilities. Dont know if this user needs a chain drive, but she does have one.
An internal hub would be a good addition for sure. The newer LaFree lites had a NiCad pack I believer?
Anyway, lets see how the reponses to the above questions come in. If the owner only has
$100, they get good fresh batteries and some advise on battery care and riding .
Thanks for taking the time to come back with such an insightful response.
