yooper2001
Established
Due to peer pressure from this forum, I am going to attempt to build my new rear wheel. There is one thing I can't find the answer or wrap my brain around without help.
The reason I need to build a wheel is because there is a lack of hub motors available 20x3 with a 135mm offset. This is an extremely common folding ebike size, so I don't know why I can't find them.
Since you guys convinced me to try, I needed to find a rim. When I finally found a 3 inch (60mm) rim, i noticed that the spoke holes on it are evenly offset from center on both sides, but to the extreme, near the outer wall of the bottom of the rim. My current Bike is also evenly offset on both sides of center , but only like 1/2 inch .
What is this greater distance from center called, and is it a problem? What is it for?
Thank you in advance for edu-micating me.
Yoop
Yoop
