I just checked the individual cell voltages on my LiFePo4 battery (36v 16Ah). It has 40 cells and is comprised of paralleled groups or 4 cells per group connected in series.
The ten 4 cell paralleled groups are all welded so it is not possible to check the individual cells in a group of 4, just the voltage of the group as a unit.
I let the entire battery set for over an hour after having fully charged it then did the measurements.
The voltage levels I measured were:
4.18
4.20
4.19
4.18
3.95
4.1
4.2
4.2
4.2
4.1
The battery only has a few charge/discharge cycles, less than 5 or 6 I think and only one of them is more than a 90% discharged cycle.
Is the one that measured 3.95 bad or is this to be considered within allowable spec.?
TIA
4.18
4.20
4.19
4.18
3.95
4.1
4.2
4.2
4.2
4.1
TIA
