Hi,
I currently have 2x5s and 3x2s lipos (because I wanted to try voltages from 24v to 48v+).
I've been charging up to 4.10v using a fake (I think) iMax charger, and not discharging under 3.75v, controlling with alarms on the balance plug.
I had a few frights while unplugging my batteries from series, to charge the 5s in parallel, then the 2s. Nothing happened yet, but I still get worried.
So I'm wondering if I could safely bulk charge the batteries, 12s for example, assuming I always keep a balancer plugged on each battery pack, or maybe a BMS. I don't know what would be more likely to fail between a fake iMax charger, a balancer or a bms.
Also, considering I would use the battery almost every day, can I keep the balancer connected all the time, over nights and weekends, or would it be safer to unplug it when the battery isn't used ? Are there any ways I could have an On/Off button for those, as I'm not sure if they alternatively use the power from every balance pin, or just one (in that case it's easy)
Also, with the alarms, I'm not sure I have them setup correctly, as they start beeping at 3.75v under load. But my battery is not even half empty when that happens. Should I set the alarm lower ? What is a safe low voltage alarm setting on load ?
Thanks for the help,
Keru.
Keru.
