Hello all, I've been reading around the forums for a while now and have decided to make my own electric skateboard (rather than purchasing one). This board will be used primarily on the campus (which is flat), and I only weigh 170 pounds. I have gathered a list of what I want to purchase, could someone please verify that these parts would work together?
The board would be a set up of 2 motors in the back, and the deck would be a loaded vanguard.
Motor x2: http://www.hobbyking.com/hobbyking/store/__18170__Turnigy_Aerodrive_SK3_4250_350kv_Brushless_Outrunner_Motor.html
would this be enough power to move me around? 2000 watts seems like enough... is the amp/voltage rating too low?
ESC x2: http://www.hobbyking.com/hobbyking/store/__84376__TrackStar_Waterproof_Brushless_1_10th_80A.html
These are slightly above the Motor amp ratings, I hope that is enough? Can I control this with Bluetooth?
Battery x2: http://www.hobbyking.com/hobbyking/store/__56839__Multistar_High_Capacity_3S_5200mAh_Multi_Rotor_Lipo_Pack.html
These would be hooked up with a Y clip to the two esc's.
Controller: A Bluetooth chip that connects to an app on my android. Is this even possible?
Am I missing any parts? Thank you all in advance.
