methods
1 GW
We are talking about non-contact isolated current sensors for higher current stuff.
Generally speaking these are $50 to $150
As price drops they get harder to work with... like they need +/-15V excitation, they have a fussy current output instead of voltage output, etc.
What you want is:
* 3 pins
* 5V input
* Output that is 2.5V +/- 1.5V to span 1V to 4V... loaded down to 10K where your uController is running 5V with a stable reference of about 4.2V on the ADC-REF
* Bidirectional
* DC capable... but fast acting... where anything that happens faster than say... a ms is not important... so.. 1khz absolute minimum
No idea of the quality on these... but the damn price is right
Datasheet:
http://www.mouser.com/ds/2/397/L06PXXXS05-22052.pdf
Direct Purchase (notice low count...)
http://www.mouser.com/ProductDetail/Tamura/L06P800S05/?qs=sGAEpiMZZMsPDRSCoHb1Xz5q%2feGrQcUB%2fpJ4eJ8yNr0%3d
Filtering that shows non-deisreable lower cots units
http://www.mouser.com/Sensors/Current-Sensors/_/N-7gqeu?P=1yxtez8Z1yuv13pZ1yuv0wcZ1yuut35Z1yuv0vxZ1yehxpg&Rl=7gqeuZer5eZ1z0x866Z1yyyqebSGT&Ns=Pricing|0
Requirement:
Current sensor for ranges 200A to 800A
Ideally a dual output with something 1/10th in the same package (one to see charge, one to see discharge)
Intent:
Tag my CAN board on the front of it
Wire directly to the chip on the CAN board
Bring out 4 wires: 12V, GND, CANHI, CANLO
Modular CAN enabled current sensor for EV
IP66 minimum rating
Target $20 value add to sensor, $20 sensor, 50% markup, $80 would be dirt cheap for an evil awesome part.
Must be something wrong as this sensors is TOO CHEAP
Help - looking to Identify THIS sensor
as found here: https://www.orionbms.com/features/current-sensor-support/
As I am sure they are getting them very cheap
thanks,
-methods
What you want is:
* 3 pins
* 5V input
* Bidirectional
Datasheet:
Requirement:
Intent:
IP66 minimum rating
thanks,
-methods
