Eujangles
Hi all,
I'm a hair away from ordering the Zippy Compact 10s 5800mah
from hobbyking http://www.hobbyking.com/hobbyking/store/__21388__ZIPPY_Compact_5800mAh_10S_25C_Long_Lipo_Pack.html
This will be my first foray in to lipo and thanks to the members in this forum as well as hobby king's tech support, I feel pretty confident about not blowing myself up.
I do have one question that remains unanswered though: hobbyking does not carry any product to monitor cells or cutoff/alarm when low voltage is reached for 10s packs. I can't find a product from anywhere else that does this either. What can I do to ride safely with this pack? I know that a cycle analyst can be set to a low voltage cutoff, but that just monitors the voltage of the whole pack. Is there a danger that 1 cell could be drained more than the rest, or will that work safely so long as the pack is in balance?
Also, if anyone knows of any way to cut off the voltage other than a CA, I'm all ears! Will a BMS do the trick? If so, where would I get one, and which one for the 10s pack?
Thanks in advance for any advice, and once again a big thanks in general to all the contributors of ES!
