M400 UART problem
Merolino
Merolino
Hello. I have a problem with Bafang M400 motor. Buyed the motor fault in torque sensor. I replace it,but the first new one arrived are fault (the electronic board on the sensor go too hot when i turn on the display) the seller give me another one,but little used (i don't know why). I think the replacement are bad like the first one,because the motor not assist when pedalling. I have connected the motor to controllerst torque and the value of the tqvoltage work fine,but if i move the pedals the other four values, speed and level stay to 0 (see attached picture). Anyone confirm that this values need to change when pedalling? And change although the assist assigned are 0? Because if this are right, the sensor of torque working but the pas integrated not, and i need to change another torque sensor assist.
Thanks in advance to all that give me an help to make work this motor
