Jonathan in Hiram
- Joined
- Oct 6, 2009
- Messages
- 446
So now I have the 100W flexible solar panel and about 1 kwh worth of 18650 cells wired up into two 6s12p pack which I run in series for 12s12p. In the future I'll probably be going to 13s12p and possibly even 14s12p.
After doing quite a bit of research into charging from solar panels to lithium it rather looks like I'm going to have to "roll my own" MPPT and charger, while searching I've found some quite interesting things. If you want to charge a battery of lower voltage than your panel's normal operating voltage there's a nice and easy circuit that uses a single comparator and some capacitors with a FET switch and appears to be a manually set maximum power point device, in this case to drive a motor but I see no reason a battery couldn't be charged instead with some minor changes in the circuit.
http://www.suburbia.com.au/~mickgg/minimax/minimax.htm
This one is probably the most interesting MPPT design I found, it uses an analog multiplier to calculate the product of voltage and current to naturally seek the MPP.
http://www.control.aau.dk/~jdn/edu/courses/11-2/best11/.../smpptfpa.pdf
And here is another analog MPPT design, I like this one since it uses only the simplest of parts but seems rather clever.
http://www.electroschematics.com/9718/solar-boost-converter-mppt-charge-controller/
I watched this entire series of videos by someone who is designing an Arduino based MPPT and has successfully marketed a PWM solar controller, it's got a lot of good information in it even though the bloke's pacing and delivery is a bit slow. I'd like to try an analog version before I get into digital I think though.
[youtube]MSz4-cr3EJw[/youtube]
What I'm stuck on more than anything is what MOSFET and inductor to use. I found a switching boost regulator calculator and have designed a 17V in 52V out regulator on it but have no idea if it's actually going to work.
http://www.daycounter.com/LabBook/BoostConverter/Boost-Converter-Equations.phtml
http://www.daycounter.com/Calculators/Switching-Converter-Calculator2.phtml
