Hi I came across a Trek Fuel EX 8. 2014
Now probably best to get the motor first before a frame,
This Trek as I figure does use a Press fit Bottom Bracket, found a few sources.
I am new here,
Any mid drive kits that can be possible with this?
AFT looks quite nice but not compatible because of the BB? Can any of the adapters work?
It's a Shimano Press Fit as far as I can tell. But I can't be sure of exactly what adapter would work.
From wiki it seems Shell Inside Diameter is 41mm and shell width is 86.5mm (road) 89.5mm or 92mm (MTB) (so 92mm on the trek?)
I know most Kits need BSA threading to be easily mounted. Do I need a different frame to get a mid Drive even compatible with the frame?
http://www.enduroforkseals.com/id443.html Will this work for me? Looks like just too BB30 which is another press fit.. Don't think it's possible on this frame.
I am wondering if I can get a GNG from LightningRods mods and improvements, AFT, or an Ego mid drive kit on this bike with the right adapter. (Or any Mid drive at all!) I'm new at this so I not even sure if I have figured what kind of BB is really in my bike but enough sources seem to imply it is indeed press fit..
Any help from the vets here would be greatly appreciated.
I am new here,
