slideNotRide
New here
My partner planned and built this setup for herself. Goal was to make the cheapest build on a BMX with as little deviation from the appearance of a park BMX bike as possible, and have a max speed under 20mph for legality. (We also both have regular BMX bikes. I might post them in the hobbies section later.)
She debated a hub motor for a long time but she really wanted the wheels to look cute. She also didn't want to have to figure out where to mount a controller. She thought of putting the battery in the middle of the frame, but decided that it was too bulky and hard to make a good looking mount, so it now sits on a rack behind the seat, inside a case that was designed to hold a portable printer.
The egirl bike:
She got an offset left crank to correct the asymmetry of the motor.
Tongsheng motor model TSDZ2B, Hailong charger model 20200, Viset 14000 mAh 48V battery pack, Aproca electronics case.
The odometer says she now has 1365 miles on this thing.
She weighs about 120lbs and rides in the city on roads and sidewalks with very few hills or large bumps. She averages around 15-18 miles per hour on throttle alone. Her typical trip is 4-5 miles one way, with occasional longer trips. This bike can also be thrown into the back of my hatchback with no wheel or pedal removal, so I can pick her up very easily. The only time she needed me to come get her was when she got a goat head in her tire, which is just normal for AZ.
The egirl bike:
