bikefan1 said:
ecycler said:
It depends on how you build the pack and how hard you are stressing them. If you distribute them evenly by mixing them into the parallel strings with the older batteries it should be fine as long as you make sure none of the old ones are self discharging and limit your DOD based on the older battery capacity. You are just looking to augment a primarily recycled battery pack, right?
This is for a new pack. I saw this
http://lunacycle.com/batteries/bare-cells/lg-18650-he4-18650-50-pack-wholesale/ seems like a good deal.
Then I would add in parallel old cells since 50 cells for 13s pack is too little. Most of the pack would be new cells.
Yikes. In that case I would go a totally different route. We need more info to make a decent recommendation.
What is the config you intend to build with the He4's?
How many recycled cells and what type do you intend to acquire?
Why F are you not just buying more He4's?
How many amps do you intend to draw peak and constant?
What is your target voltage?
Basically if you answer these questions in a way that makes sense, then you should build yourself a good pack with the new cells and use the old recycled cells to make a 'booster pack' to bump up the voltage. Put them in series to avoid damaging the good batteries and run a cycle analyst to make sure you do not deep cycle the good batteries. This is likely not going to work well as there is a huge different between used laptop batteries and He4's in discharge capabilities. My original understanding was that you did not have such disparity between the cells!
