MrBurgundy
Just offering some details for this group in order to better understand questions related to Mokwheel owners. These details may help to troubleshoot the Basalt.
NOTE: All references to wire connector numbering is clockwise from Alignment Tab in numerical order see Img. 1284. Mapping Example: 3-5 referencing "From" - "To" as per numbering order above.
1) Battery img1260,61 Model CDL4820 LI 19.6 AH, 924.924 Wh, 47.19 VDC
1a) 6 Post Battery Base img 1287,1293
Terminal Mapping
#1,4 Thin Gauge to/from solar charge port
#2,5 (2-Pos) (5- Neg) to Controller and Solar Charge Port
#3,6 Thin Gauge to/from Controller
2) Display said to be M5 img 1303, 5-Button hardwired to Display functions: Power, Up+Down Display Navigation, Headlight, Horn. Two Male cables (Yellow 3 pin, Green 6 pin)
3) Handlebar Harness group img 1312: (Red 2 pin x2 Interchangeable Brake Contacts) (Green 5 Pin Display fem), (Yellow 3 Pin Display fem), (Yellow 3 pin Throttle Male), (Yellow 3 Pin Headlight short fem) to single 10 pin at bottom bracket into Controller
Mapping From:
3a) Red Brake to Controller (1-7, 2-8)
3b) Green Display to Controller (1-3, 2-2, 3-4, 4-8, 5-5 )
3c) Yellow Display to Controller (1-nil, 2-9, 3-5 )
3d Yellow Throttle to Controller ( 1-10, 2-8, 3-1 )
3e) Yellow HEadlight to Controller (1-nil, 2-8, 3-9 )
4) Controller: two groups of three img1283. Group 1: Red/Black from Battery, 10 Pin male to display img 1284, 4 Pin to Brake/Tail light. Group 2: 2 pin Brown/Blue from Battery, 6 Pin from Torque Sensor Img 1285, 3 Pin to Motor
Harness Pin Mapping Img 1284:
5) Solar Panel Charge Port img 1298,1296 : Pos/Neg from Battery, White/Red from battery
6) Motor said to be rebranded Bafang, possibly H550 img 1305,1306
7) Bike Overall img 1309
8) Motor removed from Hub showing stamped markings. img 1327,29,30
Hope this helps someone out down the road.
Terminal Mapping
Mapping From:
