Almost finished With my first ebike build
Used an old mongoose black Diamond single to convert. motor from hpc crystalyte the Crown 60. and kelly Controller keb72120e 12kw Controller. ca v3 to have the adjustment possibilities. cut the upper frame tube and made a Box With 3mm alu that is welded in Place. and a lid on top With just a strap on it. easy to get acces to battery. sprayed With black plastidip.
Stock rear shock, previus owner has changed the front shock. i installed the hookworm tires also. knobbie dh tires is no good on asphalt..
fender not the nicest one, but alot of rain and wet road the last weeks so had to install som good fenders to stop the water.
turnigy lipo bats. 12 briks of 5s5ah total 20s15ah is it running now. peak 168ah on the ca (12kw)
. usualy i run on 6kw max on the ca. so its not Cooking the motor on a long hill.
started With a random 48v 1000w kit.. but that bike lasted 1 month before i got crasy and was wanting more power...
Picture of the bike
Picture of the bike
