see amazing story here;
http://toolmonger.com/2006/04/11/monster-garage-builds-milwaukee-v28-li-ion-powered-dragster/
The batteries in the car were connected in series to produce about 360 volts at 3,000 amperes and drive twin electric forklift motors.
vanilla ice said:Nice rack..
pwbset said:[
Wait a minute. WTF? We can't seem to wire more than 2 in series without blowing the BMS and you're telling me they did 384? No way. Special packs or special wiring or something. Look at all those beautiful connector blocks. *drool*
Jay64 said:Fechter was mentioning something about this in the EV basics section. He mentioned using diodes to protect the BMS, I don't know if that would fix your specific problem, but something to at least look into.
http://endless-sphere.com/forums/viewtopic.php?f=16&t=1312
fechter said:Jay64 said:Fechter was mentioning something about this in the EV basics section. He mentioned using diodes to protect the BMS, I don't know if that would fix your specific problem, but something to at least look into.
This setup should work for the V28 batteries too. You can stack as many as you want in series.
fechter said:You could put the diodes on the connector blocks instead of ripping open the packs.![]()
The batteries in the car were connected in series to produce about 336 volts at 3,000 amps.
fechter said:If you try to draw more current than the BMS allows, it will trip.
pwbset said:If I can find some diodes at a local electronic store I'll post a new thread with my attempt. I may ask for help here and there.fechter said:You could put the diodes on the connector blocks instead of ripping open the packs.![]()
