One Flash
Hello!
I'm at the beginning stages of an ICE to Electric conversion of a ranch UTV -- an older UTV called a "Mountaineer", mfg. years ago in Baldwin Georgia.
The current motor is a worn out Kohler Command Pro 15HP.
Most of the kits I see look to be designed for the ebike market (1000w-3000w) motors while most of the tractors seem to call for a Motenergy ME1004, (10Kw motor.)
Has anyone used the 3000w motors on a UTV successfully? It seems to me my needs are in more torque, not more speed. I welcome your thoughts and experiences with these or other kits.
The Kohler engine kicks out 3600-3700 RPM with torque in the 30-35 N.m range.
The Amazon kits (3000w) put out 4900 RPM and 5.8 N.m
I assume these motors are used as a direct or chain drive.
Side note, the Mountaineer has a 2 speed transaxle so I will have the ability to select low or high, but will the 3000w in low gear get me up a hill?
